2207 truck injectors and LS2 intake possable?
I have a early 07 GMC 4.8L out of a GMC 2500 savana 24x ignitoin custom harness to use a E40 PCm for my 04 colorado. I also have a 6 wire bolt TB for a 06 SSR that I bought.
I need to switch to a LS2 intake for clearance issues, I now have a 4 bolt throttle body, I allready of have the proper 07 and up truck water pump, to clear the TB with the new intake.
my question can I use my stock injectors wiht he LS2 intake? they have the same part number upper and lower orings, are the lengths the same? I wan to avoid the cost of new injectors and plugs, also I don't need to flow more than 24lbs or my poor unmodified 4.8L will run really rich??
I am hopping I can use a LS2 intake and LS2 rails truck injectors or just a LS2 intake wiht the truck rails and injectors?
how much for the top hat and orings? And this would be for the LS2 rails and intake? or the truck rails and LS2 intake? You wouldn't happen to know if I can use my intake bolts and gaskets would you?
