Dual in tank Walbro's, wiring help required!
I'm an idiot when it comes to wiring. Is it acceptable to run one pump on the stock wiring with the hotwire kit and wire up the other? If not, could someone supply me with some parts ie p/n's to get this right? If any sponsors have it, I'll gladly buy it all from you. I'm guessing I need a hobbs switch also for the second pump instead of having both of them run the entire time.
Our Dual pump setups come complete built in your bucket full dual wiring harness to run each pump individually and complete with a Hobbs switch. Give me a call I will get you setup.
No sorry it's all done together. We don't offer separate parts.
