12an line in a stock tank
Old 12-11-2010, 08:51 PM
nitrousjunky's Avatar
Default 12an line in a stock tank
I need to come out of my tank with a 12an line. Car is a 93 Z28. I believe it has a steel tank. I need to hook up a Maganafuel 500 pump for a carbed application. I want to use stock tank if at all possible, I dont want a cell in the hatch. Has anybody done this or have you had any problems I should know about? thanks ahead for all the input.
Old 12-11-2010, 11:13 PM
mwg2600's Avatar
Sump the stock tank if its steel. If not get a fuel cell that fits where the tank goes.
Old 12-12-2010, 10:47 AM
Mike454SS's Avatar
Pretty sure they're steel up until model year 1999, so you should be able to sump it. I've sumped a third gen tank (which I think is the same as a steel 4th gen tank other than the filler neck) without issue in the past.
