What fuel pump should i buy for ls2 d1 procharged
Im putting this ls2 in my 68 camaro.. I have a aluminum cell tank in it already so i think a inline fuel pump would work best.
Heres my set up...
LS2 gto engine
stock crank
callies rods
4.005 -11 cc dished wiseco pistons
243 heads
factory DBW 90 throttle body
edelbrock elbo
edelbrock super victor efi intake
edelbrock fuel rails
seimens 60lb injectors
Doug headers
D1sc procharger, 3.4 pulley, intercooler
let me know brands and prices if you could thanks
Heres my set up...
LS2 gto engine
stock crank
callies rods
243 heads
edelbrock elbo
Doug headers
LS1TECH Sponsor
There are many different ways to go.
Considering your forged bottom end, you will have the potential of over 700rwhp without much problem.
Since you have a custom cell, you are likely going to have to use an external pump setup.
In this case you are in need of a big single pump or dual pumps.
I can set you up with either depending on your goals, as well as the associated fuel lines, rails, regulator etc.
Feel free to call if you want to discuss your performance goals.
