can you please guys help , Auto meter Fuel level gauge
Hi , Just bought the Auto Meter Cobalt Fuel level Gauge http://www.autometer.com/cat_gaugede...gid=2576&sid=4 and the Auto meter fuel level Sender , this setup will be installed on my stand alone gallon , there're two black wires , Brown , Red , purple and White
I just want to be sure if i wired correct , I wired the Red wire to fuse panel in car near the driver side , one black wire to ground, purple to the Level sender , white to the dash lighting in the fuse panel , and there still two wires i did't wired till now the Black and Brown ?? its necessary to wire them or what ?
pleae help me guys ,
thanks in advance
thanks in advance
you dont need to wire them if your sending unit is 0-90ohms. the other black wire and brown wire is supposed to be wired to a button(switch), and pressing that switch will toggle through the pre programmed ranges
