What Injector?
Old Dec 25, 2010 | 07:33 PM
CNTLSE 1's Avatar
Default What Injector?
Trying to figure what Injector to go with. I am currently running stock shortblock with PRC LS6 heads and MS4 cam. LS6 intake and stock injectors and rails. During my tune I was held back by the injectors and made 432 wheel hp. I'm changing the setup to PRC 227 heads a FAST 92 intake and UMI 92 TB Speed Inc fuel rails and plan to eventually spray a 150 wet shot. Trying to figure out what injector to go with. I was looking at FAST 36's but would hate to be limited by injectors again but to step up to a FAST 42 is like another 3-400 bucks. So just asking some opinions on what would be good for my setup. Hope to be atleast in the 480 wheel hp after the changes. Thanks
DJ
Old Dec 25, 2010 | 07:54 PM
Greekey's Avatar
You need to look into 42 lb injectors.http://www.corvetteinjectors.com/calculator.html Use this to calculate your injector needs.
Old Dec 25, 2010 | 09:46 PM
CNTLSE 1's Avatar
yeah thinking about going with a racetronix 42
Old Dec 26, 2010 | 07:12 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Either get your injectors from us or from the corvette link above. You won't find someone better in the industry than the fuel injector connection guys!!!
Old Dec 26, 2010 | 10:03 PM
FICINJECTORS's Avatar
DJ
you can re size your factory injectors to 50lb@4bar for $200.we have an exchange program so you won't be down.
Old Dec 27, 2010 | 07:45 AM
CNTLSE 1's Avatar
Downtime is no big deal as there is snow on the ground. Interested in this resizing though. What do you mean by 4 bar?
Old Dec 27, 2010 | 08:32 AM
LS1TECH Sponsor
58psi, factory pressure.
Old Dec 27, 2010 | 12:25 PM
CNTLSE 1's Avatar
so how do you resize?
Old Dec 27, 2010 | 12:40 PM
send them in we reconfigure the discharge plate by machining the holes
Old Dec 27, 2010 | 12:54 PM
2QUIK4U's Avatar
42# injectors would probably be the best for your setup. I have never heard of having the factory ones resized but that is a pretty good price if it works.
Old Dec 27, 2010 | 05:16 PM
LS1TECH Sponsor
It works great, and, they are not just resized, but they are flow matched!!!
Old Dec 27, 2010 | 06:34 PM
Greekey's Avatar
Can you guys also replace o rings?
Old Dec 27, 2010 | 07:32 PM
We have a complete rebuilding dept. We also supply the o rings if you want to put them on yourself
Old Dec 28, 2010 | 07:16 PM
KENS WS6's Avatar
SVO #42 work great for me,I am running stage 3 head and cam with a 605 lift.
