fuel pressure gauge
Old Dec 27, 2010 | 11:23 AM
southpaw0314's Avatar
Default fuel pressure gauge
how do i attach the sender onto the end of the stock fuel rail since it has the Schneider valve? any help is appreciated.
thanks adam
Old Dec 27, 2010 | 11:59 AM
Nasty N8's Avatar
We have the correct fittings in stock to adapt.
Old Dec 27, 2010 | 02:01 PM
does it have something to push down the valve or is it just a double female connector.
Old Dec 27, 2010 | 02:05 PM
ls1curt's Avatar
you need to pull out the schrader and then put your fittings on
Old Dec 28, 2010 | 04:18 PM
koolaid_kid's Avatar
That depends on the fitting you purchase. I have a t-fitting that not only allows me to keep the schrader valve in the fuel rail, it also has another schrader valve that allows me to check the pressure at the rail to verify my dash mounted fuel pressure gauge.
