Racetronix fueling problem
It does not take much of a leak to cause the pressure to drop in a few seconds.
The regulator can also be bad, but I do not see this often.
You can check this by blocking the return line back to the tank & seeing if the pressure holds. Get a piece of solid 3/8" rod & insert it into the return hose that connects to the fuel sender. Make sure the edges are rounded so as to not cut the orings in the fitting. This will clearly prove the regulators function.
There is something you are overlooking.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
