what size AN fitting fits on the end of the fuel rail?
Old Feb 9, 2004 | 10:43 PM
Flyman's Avatar
Default what size AN fitting fits on the end of the fuel rail?
I need to install a fuel pressure gauge and it came with the male end so i belive i need a double female coupler.
what size and where to get it?
Thanks
Old Feb 10, 2004 | 09:11 AM
BlackBootyZ71's Avatar
-4an, you can get Earl's Fitting's from Summit Racing. I have the part numbers at home...the fittings were like $30
Old Feb 10, 2004 | 05:16 PM
Flyman's Avatar
So....it's a 4 AN size and is it just a coupler?
Old Feb 10, 2004 | 05:32 PM
buschman's Avatar
The problem is that the fuel rail is a standard size and the sender unit is an AN size(I might have that backwards). One side is -4AN male and the other is 1/8 npt male.
Mike
Old Feb 10, 2004 | 05:33 PM
slow's Avatar
for the autometer fuel pressure gauge, you need a -4 female, to a 1/8" npt female adapter.
local hydrolic supply places can get you what you need. Speed shops don't normally have the part, in 1 piece, but you can piece 2 adapters together to make it work.
cost at the local hydrolic supply place i go to is about 9 for the adapter.
Ryan
Old Feb 10, 2004 | 06:31 PM
if you call autometer, they will set you up with the right earl's fittings...then you can get them off of summit.
