Fuel Pressure for '02 4.8L
Old 01-19-2011, 08:38 AM
84camaroLR4's Avatar
Default Fuel Pressure for '02 4.8L
i'm swapping a 2002 4.8L LR4 into my 1984 camaro and i was wondering which fuel pump you would recommend and/or what psi the engine need to run correctly. I'm guessing since it is an LS-based engine it's going to need around 58psi like the LS1s but i just want to make sure.
Oh yea and how much flow in gph does 58psi translate to?
Old 01-19-2011, 08:51 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
Pressure should be 58psi.
Pressure does not translate directly into flow.
Flow is based on HP. You typically need .5lb/hr fuel for each HP.
About 6.2lb/gal gas & 3.77 liters/gal, translates to roughly 3.25hp/liter/hr of fuel.
So any standard pump (190lph to 255lph) that is rated for 58psi should be OK.
Old 01-19-2011, 09:12 AM
Thumbs up
dude thanks!!! that is exactly the answer my extremely technical mind needed to better understand fuel injection! that'll definitely help out with future projects
Old 01-30-2012, 12:58 PM
Need4Camaro's Avatar
I'm a bit confused - can you explain this more?
