fuel filter sock help asap
Old Feb 10, 2011 | 04:44 PM
INTENESS's Avatar
Default fuel filter sock help asap
Im in the middle of installing my racetronix fuel pump everything is going smooth till i have to snap the filter sock onto the venturi conn at the bottom of the assembly any tips on how to seat this thing on there its being a bitc-
Old Feb 10, 2011 | 06:05 PM
INTENESS's Avatar
update screwed up the sock need to order new one great,typical nothing ever goes without a hitch.
Old Feb 10, 2011 | 07:35 PM
INTENESS's Avatar
nobody has any advice
Old Feb 10, 2011 | 07:48 PM
RX-Matt's Avatar
I'm not really sure what you are referring to? Can you post a picture of what you are trying to do?
Did you receive a set of instructions with your pump?
Old Feb 11, 2011 | 04:40 AM
INTENESS's Avatar
Its not the filter for the pump that went on easy,its the sock for the venturi fuel pickup at the bottom of the assembly 1/2" round metal looking thing.Racetronics directions are outstanding have no problems with that.
Old Feb 11, 2011 | 04:44 AM
INTENESS's Avatar
Also does anyone no if I can pick this part up at your local car parts store or is this a dealer o nly part?
Old Feb 11, 2011 | 12:33 PM
RX-Matt's Avatar
We carry it:
http://www.racetronix.biz/itemdesc.a...WFS-07&eq=&Tp=
When removing that filter sock, use a small flat blade screw driver to gently separate it from the bottom of the bucket. Usually you cannot just pull it off, it will just tear the filter sock.
Old Feb 11, 2011 | 05:11 PM
INTENESS's Avatar
Im ready to call it quits man everything went like clockwork till this fnn sock wont snap on bought second one same fnn thing.Now while trying to tap it on the plastic cylander breaks typical cluster f---.So do i have now get whole new assembly?Cheapshit part cause alot of headache I need this car up and running this just sucks sorry for the rant but after a long work wk i was hoping something would go my way.
Old Feb 12, 2011 | 06:42 AM
INTENESS's Avatar
Not alot of help here no one has a idea?
Old Feb 12, 2011 | 12:21 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I believe we spoke yesterday morning.
You are welcome to call me back to discuss in more detail.
Not sure how to solve your problem as you are putting GM parts together & they do fit. I've probably put 100 of these on with no problem.
If you want I can assemble it for you... please call to discuss the details.
Old Feb 12, 2011 | 02:28 PM
INTENESS's Avatar
Lonnie your parts work awsome no problems its the gm parts that are giving me the headache.I got it resolved though I highly recommened lonnies great customer service and great products.Ill give you a call during the wk thanx again
