fuel pressure gauge
Old 02-19-2011, 10:05 AM
00 black ss's Avatar
Default fuel pressure gauge
so i have a autometer electronice fuel pressure gauge. bought it used from a member it also has some kind of AN fitting on it. where do you guys hook these up to? any write ups
Old 02-20-2011, 02:34 PM
Bump....can anybody help me??
Old 02-20-2011, 05:03 PM
WILLIAMJRDN's Avatar
Should have a test port on fuel rail. remove the schrader valve (there will be fuel pressure in the rail unless you dissable fuel pump and start car) use teflon tape on threads to seal.
Old 02-21-2011, 09:33 AM
king.speed's Avatar
Test port on the fuel rail... Be careful with the teflon tape, dont want it heading down to the injectors.
Old 02-23-2011, 03:17 PM
does anybody know the correct fitting i will need and send me a link?
Old 02-28-2011, 10:29 AM
topfig1's Avatar
Read the instructions carefully if available. Some guages use the part that threads into the fuel rail as the ground , so teflon tape will interfere. It happened to me with my Cyberdyne fuel pressure guage.
TopFig
