What Injectors???
Old Feb 22, 2011 | 04:25 AM
98 StealthZ's Avatar
Default What Injectors???
I have a stock bottom end LS1 with ported 853 heads, ported LS6 intake , ported SLP 90mm TB, Trex cam with patriot dual springs. I am wanting to run E85 because the cost of high octane fuel here is rediculous!!! What injector size would you guys recomend... Oh and I will be installing a Walbro pump..
Old Feb 22, 2011 | 04:43 AM
FICINJECTORS's Avatar
a 42 would do it. call us we have a bunch of options on 42 e85 compliant injector sets
Old Feb 22, 2011 | 04:46 AM
00MaroonZ28's Avatar
I'd do the 42 lbs. I'm running E85 with somewhat similar mods as you and still in a good duty cycle range at WOT with them.
Old Feb 22, 2011 | 10:02 PM
thanks for the input...
Old Feb 24, 2011 | 07:01 PM
RX-Matt's Avatar
Here is a link to the 42# injectors we carry:
http://www.racetronix.biz/itemdesc.a...1D030x&eq=&Tp=
We also carry a full plug and play fuel pump and wiring harness for your F-body
Fuel Pump
http://www.racetronix.biz/itemdesc.a...PA-002&eq=&Tp=
Wiring Harness
http://www.racetronix.biz/itemdesc.a...WH-002&eq=&Tp=
