L92 Truck Injectors
L92 Truck Injectors
What injectors will fit L92 Truck Intake/Fuel Rails. I am currently using stock L92 injectors and EV6 plugs. It is in the 2003 Silverado in my sig.
I ordered Fast Injectors PN 30507-8 labeled LS7, L76, L92 but they turned out shorter than stock L92 truck injectors by about 10mm.
I am just confused what injectors are used on those L92 trucks. What injectors should I order to fit directly into L92 intake fuel rail.
Attached is picture I was looking at before I order.
Will this adapter spacer resolve my problem?
http://www.fuelinjectorconnection.co...&productId=212
Thanks for the help Jon.
Which injectors does L92 truck intake have stock, left or right in the attached picture? Or do they come with both in different year models of L92 trucks?
The reason I ask is I saw this L92 truck intake on ebay with the shorter injectors while my L92 truck intake has longer injectors by 10mm. I bought mine from ebay, too.
