Submersible Fuel Hose
I am putting together a twin in-tank setup for my GTO. I have 5/16" hose running from each pump, to a distribution block. I am trying to find some 1/2" fuel hose to run from the distribution block, to the bulkhead fitting in the top of the sending unit.
Let me know where you guys have found it, or if any of the sponsors carry it.
Thanks
Thanks
I had a brain fart, and wasnt thinking about all the fittings avaliable. Im going to eliminate the need for another in-tank hose, and just run fittings. Should work well.. Thanks David!
12, fittings, fuel, hose, injection, ls1tech, place, submerisble, submersable, submersible, tank, tough
