Walbro 225 in 96 bird?
Old Feb 28, 2011 | 01:38 PM
velox65's Avatar
Default Walbro 225 in 96 bird?
Looking to upgrade my stock fueling system, mine seems to struggle at wot, all my searching turned up for 99 up install but little on the lt1 style install. What is required to do this? Wiring etc.
Thanks
Old Feb 28, 2011 | 01:59 PM
riceburnerZ28's Avatar
When you buy a pump it should come with everything needed to install minus the adhesive/glue to seal the bucket back together. You'll have to cut the factory wiring for the stock pump and supplied with the new 255 pump is a harness that you'll solder or use the crimp connectors. Its pretty simple to do....do you plan on doing the trap door mod or are you dropping the tank?
Old Feb 28, 2011 | 02:07 PM
RX-Matt's Avatar
Our fuel pump requires NO cutting/splicing and comes with the factory style fuel tube
http://www.racetronix.biz/itemdesc.a...PA-003&eq=&Tp=
And we always recommend upgrading your stock wiring when using a high flow pump.
http://www.racetronix.biz/itemdesc.asp?ic=FPWH-003&Tp=
Old Feb 28, 2011 | 02:12 PM
The product you'll need to seal the bucket back is called Seal All and you can find it at menards or homedepot. Also you might want to post this in the Lt1 section. Any other question feel free to ask.
http://www.eclecticproducts.com/sealall.htm
Old Feb 28, 2011 | 02:27 PM
velox65's Avatar
Already cut the door on it, had to replace it once before. I plan on doing a stroker before long so it will be needed, better sooner than later
