what injector driver box and injectors y'all been using?
i am looking for a good dependable injector driver box to run some low-Z injectrors. also would like to know what injectors yall recommend. i was thinking of getting the 120's from acceleronics but not sure yet.
LS1TECH Sponsor
It depends on the power level you are trying to achieve.
On gas 96's can typically get you to 1000rwhp on gas.
120's to about 1200rwhp. Idl quality may suffer with smaller motors.
Add approx 25% more injector for E85.
I have had good luck with the AEM box with the plug-n-play Racetronix harness to keep you from cutting up your wiring. A plug-n-play harness is also available for the Acceleronicx box if you want to go that route.
If you would like more info give me a call to discuss other options.
