Fuel pump
Old Mar 11, 2011 | 04:59 PM
lbm13186's Avatar
Default Fuel pump
pulling the fuel sending unit out tonight and going to send it off to Lonnies tomorrow to get the fuel set up for the pro-charger ket on 2000 trans am
any good suggestions?
Old Mar 11, 2011 | 07:39 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Depends how you want to remove it.
Some cut out an access panel which makes me cringe....
...or you can drop the tank.
Support car from frame so the suspension can drop.
Remove panhard rod, panhard brace & heat shields below tank.
Lower exhaust by loosening front clamp & disconnect hangers near muffler.
Disconnect wiring from car on dr. side in front of rear axle, remove gas cap & plastic shield under fender.
Remove small bolts from plastic around filler cap.
Remove bolt from filler tube under car.
Remove fuel line clips & disconnect line from fuel filter.
The 2 bolts hold tank in.
An empty tank makes it much easier it is much lighter.
You can do the access hole, but you cannot clean out the tank this way.
After 10 years, a lot of stuff can accumulate in there.
Old Mar 11, 2011 | 08:15 PM
lbm13186's Avatar
yep worked just like that hahaha planning on sending it to yall tomorrow
Old Mar 12, 2011 | 08:55 AM
LS1TECH Sponsor
That was an over simplified version, but touched all the major points.
Old Mar 12, 2011 | 03:37 PM
lbm13186's Avatar
shipped it to yall today from ct hopefully ull have them on monday and can get them back to me asap thanks for everything lance
Old Mar 12, 2011 | 07:49 PM
LS1TECH Sponsor
Thanks for the business. I'll keep you posted on the progress.
Old Mar 13, 2011 | 10:39 AM
lbm13186's Avatar
that would be great
Old Mar 22, 2011 | 03:12 PM
lbm13186's Avatar
hey just wondering how thing r coming with the setup please let me know thanks
Old Mar 22, 2011 | 07:19 PM
LS1TECH Sponsor
PM sent.
Old Mar 28, 2011 | 07:22 PM
lbm13186's Avatar
jw if it is going to go out this week
