Fuel injector resizing?
Old Mar 23, 2011 | 07:32 PM
TransWS6Am's Avatar
Default Fuel injector resizing?
I thought i read somewhere that FIC can resize your injectors, I have stock LS3/LS7 injectors, i'm thinking i might need slightly larger injectors, how much does re-jeting re-sizing what ever its call cost through FIC?
Old Mar 23, 2011 | 08:45 PM
FICINJECTORS's Avatar
pm sent
Old Mar 23, 2011 | 08:53 PM
TransWS6Am's Avatar
thanks for the fast response.
Old Mar 25, 2011 | 12:54 PM
litle88's Avatar
Damn, you beat me to it. How much will it cost to change stock Ls1 injectors to say 52lb'rs
Thanks
Old Mar 26, 2011 | 12:51 PM
Thanks
$200 for a complete rebuild and re size.here's the sheet.
http://fuelinjectorconnection.com/sh...iewDoc&docId=6
Old Apr 4, 2011 | 12:42 PM
bridges's Avatar
Hey FIC,
Can you resize the Green Tops that came with my 112 maggie. I think they are 42lb. What can you do for me?
Old Apr 12, 2011 | 02:45 PM
2nd Gen Fl 'bird's Avatar
Did not know you could resize a stock injector. That being said, how large can you resize and it function correctly?
Old Apr 12, 2011 | 08:40 PM
stock ls1 injectors go to 48@3 bar easily we machine the discharge plate. LS2 go to 60 ls3 72 ls9 go to 95. There is at least 2000 sets out there.
Old Apr 12, 2011 | 08:41 PM
Originally Posted by bridges
Hey FIC,
they can go to 60@ 3bar
Old Apr 13, 2011 | 09:11 AM
This is good to know, thanks.
Old May 24, 2011 | 07:03 PM
litle88's Avatar
FIC, how are the injectors as far as tuning is concerned?
Arew they just like stock or is it a little more complicated?
Thanks
Old May 24, 2011 | 10:14 PM
Thanks
Tuning a modified injector is no different than any other, the only thing changed is the discharge plate, the injector orfice nor valve is touched. All Bosch LS style injectors are the same basic injector, the discharge plate and color is the only difference. So, we copy those plates and turn yours into the size required.
Old May 29, 2011 | 12:54 PM
NemeSS's Avatar
So the stock ls3 are 42lb rating from factory? And the max after being modded is 72lb? And that charge is 200$ for resizing?
Old May 29, 2011 | 02:53 PM
KILLERARMY's Avatar
How long is the downtime to get the injector back?
Old May 29, 2011 | 07:34 PM
We need them for 2 Days
Old May 29, 2011 | 07:55 PM
4doortypels's Avatar
i have had some resized by FIC... they work great, an these guys are on top of their game... they are local for me, and i got to see their shop. they are great guys to deal with, and provide great service. i would recommend them to anyone... resized, rebuilt, new orings, flow matched, quick turn around. cant go wrong. thanks again FIC
Old May 30, 2011 | 09:00 AM
LS1NOVA's Avatar
I have used FIC for two sets of injectors. Had some LS6's resized to 60 for a turbo 5.3. Worked great. Also bought a set of high impedence 2000's but havent used them yet (same as the famed ID2000's for much less $) Thanks FIC.
Old Jun 3, 2011 | 02:20 PM
5 Liter Eater's Avatar
I was one of the first to try them out. I've been running my stock LS2's FIC resized to 60# for years now. No complaints.
