00 LS1 VS 02 LS1 fuel injectors?
While I have the injectors off I wanna put the best ones back on. Im installing and ls6 intake, Ported throttle body. I already have an SPL Lid, 373 gears, drag shocks (3 way adj), Predator programer, 2800 stall, TB spacer, rebuilt trans w/ shift kit, Nitto 555s and Im spraying a 125 shot of dry nitrous.
Should I buy some Ls6 injectors or stick with the LS1s?
The ECU is programed thinking it has a certain sized injector. If you put in a different size, using the sizes stated about 26# vs 29#, it will still open the 29# injector for the same period of time as the 26#, so you will get more fuel with the larger injector.
So, unless you get retuned...you will be running quite rich.
Ok then how about this, What if i change the ECU from my 00 and upgrade to the 02 ECU? Would that work?
