Running out of fuel
The 255 is good for at least 550rwhp.
A 200 shot will likely cause some pressure issues with the stock fuel system.
Please call if you would like to discuss your options.
http://www.bmotorsports.com/shop/pro...roducts_id/443
and put it in line with the intake 255l pump and problem solved!
Also, did you do the racetroniks wire harness with the in tank pump? The reason I ask is because the voltage increase you get with their wiring harness increases the amount of fuel from the pump significantly.
I didn't buy their harness because I made my own. Its not hard to do and is a lot cheaper!
