info needed for fuel lines
what do I need to fix it right? i attached pics, The cheapest fittings are made by Russell, so I'll list those part numbers - if you are running a -6AN line, you'll need either (only difference is color):
Russell 640850 (blue) or 640853 (black)
And if you want to run a -8AN line, you'll need either:
Russell 644000 (blue) or 644003 (black)
OR maybe you already have that line and all you need to do is move your crossover line from the front (near the throttle body) of the fuel rails. to the rear of the fuel rails (near the firewall). Then take the line that your going to take off the rear of the fuel rails, and attach it to the front driver side fuel rail. Then all u need is the quick disconnect mentioned above to attach it to the hardline on the frame rail.
lol, I just confused myself with that one........
move the cross over from front to rear.
Move the line that I assume is attached to the rear driver side fuel rail, to the front of the driver side fuel rail. Slap one of these quick disconnects on the end of the line and attach it to the hardline on the framerail.
