Vacuum Leak at injector.... O-ring??
I popped the hood this afternoon while the car was running to hear a hissing sound, traced it to the #2 injector leaking if I push down on the rail it stops so I'm pretty sure its the injector. is there a specific injector O-ring I need to run for my combo or will a stock replacement work?
I am running a Fast 102 LS3 Intake with LS2 Rails (Spaced up) & LS1 style injectors. I've never heard it before so I know this is something new I'm hoping its a fast quick fix.
Also if anyone knows where I can get actual rail spacers and not washers please let me know.
I was having this same problem, a vacuum leak coming from the fuel injector. It ended up being the #2 fuel injector was pushed down into the intake manifold too much and it pulled out of the fuel rail just enough to make noise (sounded like a vacuum leak). I pushed the injector up into the fuel rail and all is well.
