03-04 Cobra injectors on an LS1?
Hey guys, If I understand correctly the 03-04 Cobra 36lb injectors us an EV6 connector and the LS1 uses an EV1 connector? Is that so? If so is there any issue with using the adapters out there to make it work or is it just better to get an EV1 injector?
Thanks!
Thanks!
Thanks! I ended up going with a set of these..
http://www.fuelinjectorconnection.co...od&productId=5
They flow 36 lbs in the LS1 and the customer service at Fuel Injector Connectione was top notch!!
