Fast fuel rail?
Fast fuel rail?
I picked up a set of fast fuel rails with the braided ;lines and brackets from thunder racing.I currently am running a fast 92 intake the rails with the supplied brackets are not even close to working on the intake.My stock fuel rails work fine but the brackets they sent me to hold down the rails no good.Anyone else run into this problem?
Anthoner problem Im going to have is the pass side front rail conn the bracket holding the throttle cable is not going to let it sit right.I also have a wide open switch on that bracket right there works with the stock rails but dosnt look to work with the fast when I get the right brackets to hold the rails down.
