base fuel pressure?
the standard for injectors I believe is 43.5psi or 3 bar
some have/list ratings at 58psi, 4 bar.
Its all relative.
Being you are boosted, do you have a Fuel pressure regulator? What size injectors do you have? have you ever logged duty cycle or has the car not run yet?
It all depends on your setup and what you are doing with it. Keep in mind however, that as you increase boost, this pressure is pushing back on the injector delivered fuel pressure, that is why people go Fuel pressure regulator.
Its all relative.
i was told to do this with my set up.
set base to 43.5 vac line off, then at 14 psi boost you will have 58.5 psi,
i think if you change your base psi you will have to re tune your car.
If base is set to 43.5psi, that means with no boost, he will be pushing fuel into the engine at 43.5psi. When you go to 1 PSI of boost WITHOUT a FPR, that becomes 42.5 psi that he is pushing fuel into the engine with.
you will have to re-tune, as you will be changing the Injector flow rate essentially.
you can squeeze some more out of those injectors if you bump up the pressure, you should be able to scale your IFR according to whatever pressure you adjust to. and then likely lower your offset vs volts vs vac table in hptuners or the similar table in efi live.
Also, likely your MAX FPR pressure can go to is 75psi...
so 41 + 14psi boost = 55psi, so you have plenty left over.
If you up your base pressure to either 43.5psi (57.5psi at FPR at full boost)
or 58psi (72psi at FPR at full boost) as long as your injectors don't give you funny issues and you can change the tables accordingly, which should not be a problem at all, scale your IFR and your offset vs volts vs Vac table and you should be fine. Did you have injector data from the manufacturer for either of these tables? With your Injector flow rate table, it will stay constant, as you are holding fuel pressure constant across the board.
if you adjust your 41psi to 43.5psi BASE, then your Duty cycle will drop to about 82%. ( Sqrt (41/43.5)) = 0.97 * 85 = 82
Your 120LB/hr injectors are likely rated at 43.5psi so depending on your display in hptuners, on one setting you will have 120 across the board.
It simply scales from there if you change your base pressure
for instance if you go to 58psi on these 120 LB injectors
= 120 LB/hr * ( sqrt ( 58psi/43.5psi) ) = 138.56 LB/hr injectors at 58psi
if you need some help with understanding all that, PM me.
You not only have to boost reference for pressure compensation, but you also have to do so within the limits of the pump. If you try 58# base pressure & boost reference an additional 20#, you need 78psi. Most pumps will not be happy at this pressure or the flow will drop off significantly when you need it most (at high boost). The best way is to choose an injector that will support your power level while maintaining a max boost referenced pressure of under 65-70psi.
is it odd to see them rated at 4 bar?
If you up the pressure and the IDCs don't come down, you might be reaching the edge of what your fuel pump can support.
As fuel pressure increases, injectors flow MORE and fuel pumps flow LESS.
Other than using tuning constants, I refer to the 3 bar pressures.
then use this base pressure to calculate the IFR table using the squareroot formula (and populate the same value in all cells horizontal/flat across).
