no injector pulse.. please help!
Old Jun 9, 2011 | 01:03 PM
GITSUM95Z's Avatar
Default no injector pulse.. please help!
i have a 1995 camaro. stock computer, stock wiring harness. the motor 383 LT1. i have stock heads, intake. MSD 6al box, coil, msd pro billet dist. comp cams 306. i had taken the engine out and had it refreshened. i done a abs delete, and wire delete (ran harness along the frame rail). i have all grounds hooked up and making good contact. im getting fuel all the way to the injectors. im getting spark out of all 8 plugs. i thought the dist was bad so i replaced with a brand new msd pro billet. the motor turns over but will not take off. im not getting injector pulse. im stumped. someone had mentioned the vats system may be causing this but i have no idea. any advice or help is much appreciated.
