Magna fuel 4303 with fuel pump controller
Here's my setup magna fuel 4303 pump with the 9550b regulator and 7006 pre filter. I'm running -12 from tank to pre filter and pre filter to pump. From pump to regulator is -10 and regulator to fuel rails is a -10 also. Return to tank is all-10 line. This is a street strip truck on e85 engine should be around1,000 hp. My question is can I run a Weldon fuel pump controller with this setup? I know magna fuel says absolutely no add a fuel cooler to the return line. I just don't want to add ice all the time during the summer to keep the fuel temp down if I need to. Maybe this setup won't need a cooler? Thanks for the info.
MagnaFuel does not rec a controller with their pumps. And you need to regulate after the rails before will not control the pressure properly.
Run the feed split to the rails then out the rails to the regulator.
