LS1 fuel system/lines
Old Jun 25, 2011 | 07:33 PM
jasonbowling's Avatar
Default LS1 fuel system/lines
i have a 68 camaro with an LS1 engine. I have a rockwood fuel tank with internal pump etc. My question is what is the best fuel line set up as far as flex lines and pressure regulator etc. I know there is a way i can run a single line without having to have a return. Can someone give me some information or lead me to a vendor that might be able to? thanks in advance
Old Jun 25, 2011 | 08:04 PM
cmaurice876's Avatar
We just did a 77 corvette conversion. We used a c5 corvette fuel filter/regulator. It is part number 3737 at napa. This filter has the regulator built in and a return line. If you have a large enough pump you should not have a problem getting around 57psi at the fuel rails. We then used stainless braided line from the regulator to the fuel rails and just some transmission oil cooler lines from the tank to the regulator (Feed and return) with two hose clamps on each quick disconnect.
Here is the regulator
Here is the lines and fittings
Old Jun 25, 2011 | 10:53 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Give me a call & I'll be glad to help you out.
The regulator & return style is largely dependent on your power level.
Old Jun 26, 2011 | 07:17 PM
slippi84's Avatar
PM sent
