Racetronix hotwire for 2nd fuel pump ??
I have an exsisting hotwire and Walbro 255 set up
I am adding a 2nd Walbro 255 and have a 2nd hotire kit to power the pump.
What do I do wire the 2nd pump to utilize it's relay?
I am using a Hobbs switch, powered from the alternator.
2nd pump will not be plugged into fuel sender / PCM, etc right?
Do I permenantly jump the relay to bypass the factory power supply connectors?
PWR @ alt -> Hobbs -> relay -> pump , right?
