Fuel PSI go to Zero when shut off.
I installed a boost referenced Aermotive reg on my LQ4 1981 TTA swap, added turbo, and intercooler. Well after giving the car a little boost, the fuel gauges go back to zero when the car is shut off. All before it would hold 40-50 for a long time, I checked for leaks, and dont see any. I have a external 340Walbro. Will the FPR send the fuel back to the tank, and cause fuel psi to drop? Car run good other wise.
I pinched the line from the FPR and the fuel psi stayed up 100psi with car off, then took the pinch off, and it stayed at 40-35psi. Being its boost referenced it still should hold psi right?
@100psi, you evidently pinched the line while the engine was running!
@100psi, and it holding, is a pretty good test for the system components behind the regulator.
That hi psi against the pump may have knocked the check valve back into position. [Assuming it has 1] Holding 35-40 after release is what I'm basing the comment on.
Now, after the test, does the system hold psi after running and shutdown?
Boost reference has nothing to do with retention of fp after shut down.
