Help with Bosch 1600cc Idle
Now where is that video I posted, that a vendor had removed? It was a you tube video showing spray patterns on a high speed camera. It seems the moderator that removed it and said I was pushing some injector might have a bias? Cause just seeing it, in this case, definately could have avoided this thread entirely.
Good luck with the idle......I went another way but Im not allowed to tell you.
FYI, I'm planning on maxing out this turbo on my setup, which should be around 20psi I'm thinking on this setup.
When going from 4 bar to 3 bar, are you just adjusting the injector tables?
Those injectors are the old Ford 160s with the light grey (white) top correct? Those are pretty nasty down low with some funky characteristics but still tuneable.
The injectors are indeed the whiteish top "Bosch" or "Ford" type.
From looking at logs, looks like she idles in the 40kpa range.
OK on the injectors, I have data for those for aftermarket computers but it's fairly straight forward to convert to LS1 PCM format. I'll work on that shortly...
Idling around 40 kpa is what I was afraid of, you are at the mercy of that old MAP sensor at this point and if you want more driveability and accuracy you will need that newer sensor.
I appreciate the help. I just got a base tune on our RX7 project as well, so I can use what I learn here with that. It's a 5.3 with a GT2-3, good springs, LS9 gaskets, ARP hardware and a 7875 as well. It's scary already on 8lbs. Also on E85, the 60lb injectors on that are already done though. Will probably tune that one in on the dyno now at the current boost and leave it until my buddy learns how to drive it, haha.
