Anyone use the AEM flow monitor for meth yet???
I just bought the AEM flow monitor to measure the amount of meth I'm using. The part number is 30-3030. It has data logging and a bunch of other things it can do. I'm using a alky kit and I was wander if I can hook it up to the progressive controller to measure the percentage that the pump is running at. It has a wire for that but im not sure where to hook it up to on the alky controller. Here is a link to the controller http://www.aemelectronics.com/water-...e-1-4-sae-1184
Have you contacted AEM about it? I know that AEM uses a ground signal to pulse the pump. I have a Devil's Own that I will be hooking up to it when the controller gets bought and sent to Japan. I think all other companies pulse +. I don't know how the flow monitor would handle it.
