ls1 aftermarket rails on 5.3 lm7
Hi
I have got a lm7 that i am putting at gt45 turbo on, and as i need bigget injectors i am thinking of putting bigger fuelrails on it to.
but can i just put in ls1 style injectors (the longer ones) and then use a ls1 aftermarket fuelrail set?
thanks Mads
thanks Mads
with going through all that i would just get an ls1/6 intake and then the fuel rails but also your injector plugs are going to be different from the 5.3 injectors most likely, i am doing a 5.3 swap in my 91 camaro thats the problem i ran into but i had my harness re worked so he put the new injector plugs on there for me
