car shuts off while driving!
things i did to try solving this issue: redid all my grounds,clean the whole throttle-body including tps,maf,etc..car still doing the same thing.also once a while the coolant light comes on but i checked all fluids are good.also i checked the oms and voltage on the injectors.oms are right around 12.9-13.0.and voltage id around 10.it has stock injectors.
according to the last owner the car has mild cam, headers,borla exhaust,heads were redone,and the car is dyno tuned.i did everything but nothing seem to work.someone please save my car before i sell it.
A data log and a fuel psi gauge on the windshield would be a big step towards finding the problem.....................
and this is after it decides to start up:http://youtu.be/mNeEAWwBISo
i am not worried abt the code its throwing because that code came on yesterday and the car been acting like this for abt month.
regardless you might wanna know what code/codes it has.
might wanna read the tps see where its at or what its doing.
also IAC as well.
i had a tps sensor code come and go. spring was sticking.
play with the tps and reset it a few times just played with it and the apparently unhung its self.
so far no more drop in the idle like yours is doing. plus i am running a stock air box and car is starving for air according to the IAC readings.
just a thought
good luck
also IAC as well.
just a thought
good luck
http://youtu.be/cUnhnhynXZ4
THIS IS WHEN THE CAR BOGGS OUT.
http://youtu.be/weC2jcBucX0
Let us know what you find.
Are you sure about all your grounds. I had one come and go on my MSD window switch. Sometimes it would work sometimes not.
my fuel pressure doesnt drop like urs does.
can the fuel pressure not drop and the FPS be the issue?
mines a 95 camaro v8.
venturi could have popped off or be kinked or not even hooked up or not supplying enough fuel back into the bucket.
make sure your straw from the pump to the bottom side of the module/sending unit is a good seal.
i have installed several of the racetronix pumps and have not had one issue.
i installed a walbro on mine and i had to replace the rubber hose that goes from the pump to bottom side of the module/sending unit and use efi hose clamps,they are tapered on the inside.
good luck
