Stock fuel supply line will be the Return line !!!
soon i'll going to install my new fuel system
its dual 255 in tank i'll run new 8AN supply line and i think to save time and place so i wondering about if i can use the stock supply line as return line since it 6AN !!!!
but there is few point regard the filter , can i use filter for the return line ?
and if its not what fitting should i need to remove the filter and use new 6AN
hose ?
hose ?
I wouldn't reuse THAT filter for the return. If you do it'll just blow all the **** that it filtered back into your tank. If you must, get a new one. I would just run a -6 return while you're at it and do it right. Just IMO.
It is almost easier and doesn't save a whole lot with special fittings and new filter needed and its slightly smaller than -6. It's only a couple extra feet of -6 line needed to complete. Give me a call I have complete line kits available even budget kits.
