Fuel Rail Hardware
Old Oct 30, 2011 | 10:55 PM
the_merv's Avatar
Veteran: Air Force
Default Fuel Rail Hardware
I'm looking at putting a Vic Jr on my MCSS, it has L92 Heads.
Here are the Rails I'm looking at..
http://www.summitracing.com/parts/EDL-3638/
What is a good fitting kit for the Fuel Rails that will hook to them and come out to a 3/8" male quick connect so I can run it into the Stock Line I have on it?
Thanks.
Old Oct 31, 2011 | 09:41 AM
mebuildit's Avatar
Aeromotive sells these at Summit. These are what you are looking for.
http://www.summitracing.com/parts/AEI-15117/
Old Oct 31, 2011 | 04:10 PM
the_merv's Avatar
Veteran: Air Force
No thats not it..
I'll rephrase..
Vic Jr Intake.. using them Rails. What Hardware do I need to get it from the stock GM Line to the Rails? Is there a kit?
Old Nov 1, 2011 | 05:02 PM
the_merv's Avatar
Veteran: Air Force
Ok since no one understands I'll break it down Army retard style..
See how the Factory Rails have the Male 3/8" QC End on them..and the Fuel Line is a 3/8" Female QC..what hardware kit will get a set of them Billet Rails to the stock Female 3/8" QC Line?
That should work since this has 50+ views and no one can seem to understand...
Old Nov 1, 2011 | 07:28 PM
the_merv's Avatar
Veteran: Air Force
Better question would be is there a complete Rail and Line Kit that will do what I need and bolt to the Vic Jr?
Injectors are GM LS7.
Old Nov 1, 2011 | 08:18 PM
gregrob's Avatar
https://ls1tech.com/forums/fueling-i...stem-pics.html
Doit
Old Nov 1, 2011 | 08:31 PM
the_merv's Avatar
Veteran: Air Force
Some of them fittings arent what I need..someone has to sell a kit for this ****..
Old Nov 2, 2011 | 12:23 AM
the_merv's Avatar
Veteran: Air Force
Professional Products fitting # 52181, 3/8" Male QC, 90*, 3/8" NPT, that one will be the inlet.
Just have to find the Cross-over and a Schrader Valve that is 3/8" NPT to 1/8" NPT, or 3/8" NPT to -4AN.
