Fuel filter with 3/8" inlet and outlet
I need a fuel filter that will support the ls1 fuel pressure but I can put 3/8" inch fuel hose on each end and clamp down. Anyone know of one I can get from the local parts store?
Odd
You want a filter that can handle the pressure of a LSx system to use clamps not rated for the pressure and special high pressure hose more expensive than AN6 line/fittings...
To answer your question, any filter from the 80's with a threaded fitting on each side will work. Get saginaw to 3/8" barb fittings. Will work fine until the car burns to the ground
Please be a little more kind. I like this forum and I don't wish to be reprimanded like a child on it. Your advice is helpful though so please be that kind person to help with it. Share your understanding, don't throw it at me like an insult.
