In-line or In-tank Fuel Pump?
Old Mar 17, 2004 | 11:09 AM
Gold Phoenix's Avatar
Default In-line or In-tank Fuel Pump?
I noticed today that my fuel pressure gauge on the injector rail was reading 50psi at idle. Should I be concerned? If so, which pump should I get?
Old Mar 18, 2004 | 06:18 AM
smokinHawk's Avatar
walbro 340 intank is a must
Old Mar 18, 2004 | 06:42 AM
Fast SS on TNT's Avatar
Ditto. Walbro 340. Maybe add a hot wire kit, and a voltage booster for a top notch setup.
Old Mar 18, 2004 | 12:55 PM
Nasty N8's Avatar
Yes add a Walbro GSS340M intank pump and a hot wire kit. We keep these pumps instock $110.00. Will support your car to 600-700HP.
Nate
Old Mar 18, 2004 | 01:12 PM
Flamin Raven's Avatar
Definately get an intank. They're cheaper and better
Old Mar 18, 2004 | 08:06 PM
Classic Style's Avatar
How about when you have to use an external fuel pump? What would you recommend in that format? I am putting an LS1 in my Porsche 911, and can't put an intank, in the tank.
Classic
Old Mar 18, 2004 | 09:16 PM
Sump tank with an Aeromotive pump. Or a bosch 420lph inline.
Old Mar 18, 2004 | 10:47 PM
IntenseSS's Avatar
Nate
Sounds like a good deal you got PM
Old Mar 20, 2004 | 04:05 PM
Who would you recommend as a good retailer for the bosch pump?
Old Mar 20, 2004 | 06:32 PM
VINCE's Avatar
Shorty Director
Nate
How much would it support with the volt booster as well. I have all three.. Walbro 340, Hotwire Kit, and volt booster. I am talking RWHP. I have a friend who is running 600 to 710rwhp with the walbro 340 and hotwire kit with no problems. Rumor is you can run a universal fuel pressure regulator off the fuel rail and you will be able to support even more horsepower. Is this true?
Old Mar 20, 2004 | 08:24 PM
99 Black Bird T/A's Avatar
Friend has a Walbro 340 as an external inline pump. It's VERY LOUD. Very annoying. I would avoid doing an inline pump after hearing how loud it was. In tank is the way to go.
Old Mar 21, 2004 | 04:36 AM
Black02SS's Avatar
I added a inline to my setup and it wasn't enough and yes it is somewhat loud. I have since added a intank and left the inline. I would get a intank if I had to do it over and not the inline.
Old Mar 21, 2004 | 09:40 PM
BudH's Avatar
Walbro intank!
