#2 cylinder no fire
I got a DTC of 1151 1153, 1154 all bank 2 O2.
I replaced the O2 and I cleaned the plugs.
I thought that was it.
On my test drive, I had a complete cylinder drop.
I water tested which cylinder wasn't firing. I got #2 no fire.
I pulled the plug smelled it, didn't smell fuel, replaced the wire and checked for spark.
Got spark. Still no fire.
No noise in the engine, no metal in oil. I pulled valve cover, all ok there.
So I've almost run out of ideas. I don't have a compression tester yet and I don't know how to check for injector firing. I thought about swapping another injector to see if the missfire moves. I did tap on it and still nothing.
Please let me know. I hate a car running on 7 cylinders.
that would confirm valve train or internal engine issue. I pulled valve cover, no metal in oil, springs/rockers are good.
I'm leaning towards the injector. Going to put everything back together and test injector. I've already confirmed I got power to it.
