Lonnies dual pump install questions....
Does anyone here have any insight on how to install the wire harness for the lonnies kit? Or even pics? I'm going to install it this weekend, and I'm a bit lost on the harness. I hear how everyone says it's plug and play. Does this harness directly replace the previous stock harness? Or is it straight forward when your under the car with the harness in hand? I could post pics of the kit if it helps. I just hate dealing with wiring personally. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
It is a 98 kit, but I don't think that will make much of a difference for the wiring half of the install.
Thanks in advance!
Thanks in advance!
Thanks, I'll give you a call today!
Yeah it's a Hobbs switch I believe. And I am boosted. Just need this fuel setup for my new motor. I'm hoping it's easy. But I'm just a bit lost. Do you have the same setup? Any chance you have pics of the wire harness installed?
