Fuel system routing diagram? Lonnies double pumper -8feed/-6return kit
Old 02-22-2012, 08:52 PM
jt76's Avatar
Default Fuel system routing diagram? Lonnies double pumper -8feed/-6return kit
I have a lonnies performance fuel system with a -8 feed and a -6 return. Speed inc fuel rails and a fuel lab regulator. I want to mount the regulator on the front of one of the rails. How should i run the lines? I was under the impression that i should have a y block off the -8 line and have it split to the back of both rails. From there i'm lost... any advice on how to do this? What AN fittings will i need if anyone has done this before? any pictures of your setups? Thanks guys.
Old 02-22-2012, 09:18 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You do not need to Y the rails, as a series connection has been proven on 1000+rwhp applications.
If you bought my kit, it already has all fittings required.
Feel free to call if you need more info on the kit.
Old 02-22-2012, 10:25 PM
jt76's Avatar
I bought your kit off a member here. So i didn't get all the fittings... i have everything complete up to the engine bay where the feed ends at a 90* elbow and the return is just a normal connection. Do you have a picture of your kit installed? Thanks for any help
Old 02-24-2012, 01:42 PM
jt76's Avatar
Bump anyone have picture?
Old 02-24-2012, 05:41 PM
LS1TECH Sponsor
I do not currently have pictures, & there are variations on how to do the install.
I offered to help you but you never called.
Quick Reply: Fuel system routing diagram? Lonnies double pumper -8feed/-6return kit
