Need some pump advice!!!!
Old Feb 25, 2012 | 03:19 PM
Swaie's Avatar
Default Need some pump advice!!!!
I am doing a custom front mount with a gt45 turbo, running about 8psi 10 with meth on a 02 z06 cam on a stock displacement motor. I'm wondering if there is a pump that will support what I need for fuel. I've been looking at the racetronix kit and about to pull the trigger, but I just know know if it is going to support the set up or not...Please help!!!
Old Feb 25, 2012 | 03:50 PM
Swaie's Avatar
I read the Twin pump sticky...I noticed that some people stated that if you run it below a 1/2 tank the pressure drops...I have a 00 car so I don't have a baffle in my tank...Is there a fix for that...or should I just go with a racetronix 310 or something like that? input please...
Old Feb 25, 2012 | 07:35 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
A single Racetronix will get you to approx 550rwhp.
I'm not sure of your ultimate power goals.
Give me a call if you want to discuss in more detail.
I can work with you on a kit to keep you from buying things twice.
