Compressed natural gas for high hp use (why can't it be done?)
Old 03-27-2012, 10:16 PM
GulfM3's Avatar
Originally Posted by 5.3-on-steroids
This is amazing, cost isnt an issue. Im determined to prove a point here. But what I need to know is how do they rate the flow on these injectors being that they don't flow liquid and if doing a rail setup like this if it deletes the need for a reducer (the mecanisim that takes it from 3600 psi to 5psi) and what fpr ect. So many grey areas but so close to reality.
looks like they are rated for 700kpa, or 100psi, which makes sense because thats the norm for traditional "fogger" style CNG systems. You will still need a regulator to drop the tank pressure to 100psi.
Also I found a couple forums stating they are good for 55hp each, in which case you would need to run two per cylinder to make real power.
Old 03-31-2012, 11:47 PM
BBrown79's Avatar
i was thinking about 11:1 for a boosted app. the valves need to be grinded at a different angle to reduce wear with ng. also the seats need to be of stellite also or the will wear prematurely. there are kits out there that run their own ecu for the ng. the flip of the switch your back to oem petrol.
Old 04-01-2012, 12:01 AM
BBrown79's Avatar
Default CNG works at Talladega
LPG 4.0 liter with a T51. ugly car but runs pretty good for a I6. im wondering what the enrgy density is beteween lpg and regular ng?http://www.youtube.com/watch?v=p8NdXG_t95U
Old 04-01-2012, 12:59 AM
time3777's Avatar
Let me know how your acetone test goes man, I work at a chemical plant and we make around 1200 tons of acetone a day.
Old 07-21-2015, 09:32 AM
Blazin24's Avatar
Default Results?
I know this is an old thread, but did anyone ever do this or get any results? I'm very interested in doing this myself as I'm about to pick up a gas converted Tahoe. Please chime back in...!
Old 07-22-2015, 04:38 PM
stevieturbo's Avatar
There were a couple of threads a while back, I think in the boosted section, of a couple of trucks with turbo CNG setups. I think they used older mixer ring type installs.
Quick Reply: Compressed natural gas for high hp use (why can't it be done?)
