Need to learn about boost reference fuel pressure regulator.
Right now I have Lonnie's double in tank setup with a hobb's switch activating the second pump at ~4lbs of boost. I have Speed inc fuel rails, and other than that, a stock fuel system.
So how difficult/easy is it to go to a boost reference fuel pressure regulator?
Set your fuel pressure with the car idling, vacuum line disconnected.
Then connect vacuum line.
Adjust your injector flow tables for boost reference, which sets the flow table to the same number across the board, since the regulator now adjusts to compensate.
Under boost you will now be rich as the additional fuel pressure will increase flow.
Another lesson learned after the fact.
Lonnie, I haven't called because I've just been too busy. I don't think I have 200 miles on the new motor since finishing it on July 1.
Once you exceed this power level the factory regulator does not control the pressure that well. At this time it is best to locate the regulator at the front of the car with a return line. Then you can boost reference it & help out with your injector flow at high boost levels.
You can use the evap line, but personally I would rather leave the EVAP system intact. I think it is easier to run a new line 10' than to reconfigure the evap system.
Heres a few pics on how i ran mine.
6 AN Male To 14mm x 1.5 O-Ring plug for the t-block and a 6an cap of course.
6AN Male To 5/16" Quick Disconnect Male Fuel Fitting to hook up to the stock plastic fuel line in the back. its in the baggy if you cant see it lol
just to make sure though, i still hook it up to the brake booster hose right for the vac/boost source? just making sure
if its just hooked up to boost,ie before TB, its doing this anyway right?
just want to make sure i hook it up right
