255 in tank + 255 in line
Old Apr 28, 2012 | 11:36 PM
1toofastlt1's Avatar
Default 255 in tank + 255 in line
I have a 97 camaro with a 383 and a supercharger right now i have 60# injectors and the stock in tank pump with a 255 inline. My question is how much horsepower will running a 255 in tank with my 255 in line support?
Old Apr 29, 2012 | 08:31 AM
Mr. Fuel Pump's Avatar
If you run in series, you will get no more flow than just the inline pump (closest to the engine) can deliver-which a 255 high pressure pump (GSL392) will support about 450rwhp depending on your fuel pressure. If you run them in parallel/dual, you can support about 750rwhp
Old Apr 29, 2012 | 08:37 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Typically adding an inline pump does very little to boost the flow.
These are usually used to boost pressure (such as with a FMU on boosted cars), but will not do much if you are running normal pressures.
If you are interested in a pump system for your car, give me a call.
I can get you the best setup for your needs.
