-10 feed with -6 return
Old May 16, 2012 | 07:13 AM
oneoverwrx's Avatar
Default -10 feed with -6 return
I am currently building my car with a turbo 4.8 setup. This will not be my last set up in this chassis, it could very well go to 1000whp next time around. With that being said, I have been given a piece of -6 line long enough for a return line. A friend of mine will sell me a piece of -10 very cheap and he has the hose ends I can get too. I don't like building stuff twice and with what I have available will this work? I had planned on possibly reducing the -10 line to -8 with a reducer right before the rail. In theory this would make it a -8 feed but with higher volume right? Planning on running e85 and being in the 700whp right now. Any suggestions are welcome.
Old May 17, 2012 | 10:35 PM
Twotonefreak's Avatar
Do yourself a favor and go ahead with a -10 return or at least a minimum of -8. A restriction on the return side will cause psi issues.
Running a -10 and splitting it into -8 to feed each rail will be just fine. I actually did my vette that way.
Old May 18, 2012 | 07:34 AM
oneoverwrx's Avatar
I had considered that but that totally goes against why I would consider the -10 feed. Budget. Will reducing the -10 feed to -8 prior to the rail not effectively make it a -8 feed?
Old May 18, 2012 | 08:57 AM
MIGHTYMOUSE's Avatar
i run a 10 feed with stock feed as return, which is smaller than 6.
its more about your regulator, and fuel pump, how many, what speed, and when they come on
Old May 19, 2012 | 03:21 PM
oneoverwrx's Avatar
Pump will be a walbro485, regulator is an aeromotive a1000 (13101). -6 ports.
Old May 20, 2012 | 07:41 AM
bayer-z28's Avatar
What size is the stock LS feed line anyway?? I figured it was 5/16 or -6. Had some -6 on my last fuel build and it looked like a pretty darn close match.
Old May 20, 2012 | 10:15 AM
stock line ID is like -5 ish. when i measured like 8 years ago at the tight spots lol.
Old May 25, 2012 | 11:13 PM
js2fst's Avatar
What will happen if you go to a -6 regulator? Won't that drop be too much
