Would I??????
Old Jul 6, 2012 | 10:50 AM
01transampower's Avatar
Default Would I??????
Would I be able to run E-85 with 42lb an hour injectors on a heads cam only motor? All my mods are in my sig.
Old Jul 6, 2012 | 11:27 AM
vaticano's Avatar
Yes. That's what i did at first.
Old Jul 6, 2012 | 01:09 PM
What kind of increase in power did you see? From 91 or 93 octane? And did you run your stock fuel line with it?
Old Jul 6, 2012 | 05:15 PM
vaticano's Avatar
Can't really say. I did not get it on a dyno, and I'm really not set up for drag racing so my times are always bad.
I later used the stock fuel lines with 2 pumps and 79# injectors at 58 psi. So the fuel line wont be an issue. They flow plenty for what you have.
Old Jul 6, 2012 | 08:33 PM
Do you know how long the stock fule line would hold because I am being told I need to upgrade them so the e-85 doesnt chew through the stock stuff.
Old Jul 6, 2012 | 10:21 PM
vaticano's Avatar
Don't believe the hype. I used them for 4 years or so for feed lines and now use the feed as a return for the last 2 years. I also run E-85 in my 05 GMC Sierra. It has 170,000 miles on it half using E-85.
The only issue I have seen is it leaves a sticky residue around the injector tip. Just run some 91 through it every so often and it cleans it off.
Old Jul 7, 2012 | 06:15 AM
Ollie8974's Avatar
Originally Posted by 01transampower
Do you know how long the stock fuel line would hold because I am being told I need to upgrade them so the e-85 doesn't chew through the stock stuff.
E 85 will not "Chew through" the stock nylon fuel line.
Old Jul 7, 2012 | 09:48 AM
good to know guys thank you. Going to the tuner today and wanted to makesure i could go e-85 if i really wanted too.
