fuel pump not priming ?
Old Jul 9, 2012 | 09:57 AM
devic's Avatar
really cause last time i drove my car it just kinda powered down, is there a way to find out if i have a bad ground ? but 1 of the starter mounts had broken off some how lol, so i figured that was the cause of the car stopping
Old Jul 9, 2012 | 10:36 AM
USMC35thSS's Avatar
I just put a jumper wire on 87 and 30. As long as power is going through the fuse and to the relay then you should be getting power across the jumper and to the pump. Just check either 87 or 30 for power. I can't remember which one should have it. After you put on the jumper you should hear your pump running. If it doesn't then either your pump is bad or power isn't making it to it. If the pump does run then you need to troubleshoot your relay. If the relay is good then I would assume it has something to do with your PCM. Not too sure though.
Old Jul 9, 2012 | 10:39 AM
USMC35thSS's Avatar
It's a good thing My6SpeedZ stepped in because I didn't even think about the grounds. Can your multimeter do continuity check? That would be an easy way to check your grounds.
Old Jul 9, 2012 | 02:38 PM
devic's Avatar
would i do that test at the back of the car see how strong the signal is ?
Old Jul 9, 2012 | 03:24 PM
USMC35thSS's Avatar
You might as well check your power first. When checking your ground you will check the resistance of the wire or check continuity. Did the pump come on when you used the jumper? If not check for power at the jumper then the gray wire closest to the pump. We need to be sure power is getting to the pump before we check anything else.
Check power on both sides of the fuse. Remove the relay and install jumper at 87 to 30. Check for power at both. If you still have power check power at the connector above the axle. Let us know what you have from there.
Old Jul 10, 2012 | 01:23 AM
devic's Avatar
kk i just got off work a bit ago so im going to check all this in the AM,
i think im going to go ahead and order that pump and wire kick cause if my wiring bad, im going to need it any way, an ill be right there at the pump so i might as well get it too while im at it what you think ?
Old Jul 10, 2012 | 07:35 AM
USMC35thSS's Avatar
I will probably end up being a bad pump. But those wire kits still need the existing wiring harness to work.
Old Jul 10, 2012 | 07:53 AM
devic's Avatar
jumped 30 - 85 with and without relay pump still not on just gotta get under the car and test the volts back there now
o yeah was thinking it didnt matter but i forgot that they clip in all the way back at the pump
so i guess im bout to order this pump i just ordered the wiring figured i probably needed it any way, u think i should go with the stock replacement or the upgrade 122 vs 160, but i probably wont hit 600 hp any time in the near future
Old Jul 10, 2012 | 08:08 AM
devic's Avatar
dude on here says he got the upgraded 1 for 125 shipped think i should go with that ? idk tho low number of post so kinda weary
Old Jul 10, 2012 | 06:34 PM
USMC35thSS's Avatar
Jumping those with the relay out won't help you at all. If you are going to jump anything with it out it needs to be 30 and 87. Did you check for power at the connector in the back when you jumped it with the relay in?
Do you have someone that can turn the key on while you check for power at the connector in the back? If so then put the relay back in (make sure it's in right) and one person turn on the key while the other checks for power.
The wire kits for the fuel pump allows less of a voltage drop to the fuel pump allowing for more flow and pressure for upgraded pumps. I think the stock wiring is ok with a stock pump. But if you do decide to upgrade your pump then you should get the wiring harness as well. Just my opinion.
Old Jul 10, 2012 | 06:54 PM
devic's Avatar
i didnt have any 1 to help me test the voltage today so i was unable to do that, hopefully my brother will be here tomorrow and be able to help me out with it
Old Jul 10, 2012 | 07:17 PM
  #32
USMC35thSS's Avatar
Ok. You can always take the relay out and put the jumper wire on 30 and 87 and see if the pump comes on. If not check power at the connector.
Old Jul 11, 2012 | 04:47 PM
  #33
devic's Avatar
ok bout to cut out the trap door, and test all the wires, wish me luck lol
Old Jul 11, 2012 | 05:51 PM
  #34
devic's Avatar
trap door is cut, came out better then i expected bout to test the wires see if its getting steady voltage
Old Jul 11, 2012 | 06:21 PM
  #35
devic's Avatar
ok so grey wire at pump is only getting power when 30 is jumped to 85 on the relay, this is the connector the directly plugs into the pump on top the gas tank
and the sending unit is only getting bout 8 volts
also tried swapping all 3 relays still no power back to the pump unless i jump 30 - 85
Old Jul 11, 2012 | 06:40 PM
  #36
devic's Avatar
well turns out the fuel pump was bad i finaly checked it myself instead of just taking my friend word that is was good when he checked it, well it was bad, so now there power to the grey wire at the pump but it is still not kicking on
Old Jul 11, 2012 | 09:32 PM
  #37
USMC35thSS's Avatar
Awesome. So a new pump will do the trick. How did the hole come out? Mine was a disaster when I did it.
Old Jul 11, 2012 | 09:38 PM
  #38
USMC35thSS's Avatar
Sorry I didn't see that you had commented on it.
Old Jul 12, 2012 | 12:13 AM
  #39
devic's Avatar
its all good man, the hole came out really well, went to my friends shop and cut a piece out bout half inch bigger on each side to cover the whole with, ill post a pic lil later when i get home. i ordered the pump and wiring kit already in anticipation of the pump being bad, so should be here in the next few days, cant wait for it to get here paid 30 bucks for 3 day shipping from racetronix pretty ridiculous if u ask me but its what ever lol.
i was thinking while im here i might make a whole actual trap door kit out of diamond plate with a twist turn lock and a hinge or something what u think ?
so seeing how im now getting power back there, it is for sure the pump right. just making sure ?
Old Jul 12, 2012 | 12:22 AM
  #40
devic's Avatar
oops just noticed i worded that wrong in that post u quoted, but the same result im sure. i meant to say the fuse was bad after finally checking it myself instead of taking my friends word for it when he checked it, so now im getting power to the pump but it is not kicking on regardless so im pretty sure its bad
