fuel pump not priming ?
Old Jul 12, 2012 | 02:27 AM
  #41
devic's Avatar
my trap door mod =] . first time using a cut off wheel as well
Old Jul 12, 2012 | 11:30 AM
  #42
USMC35thSS's Avatar
If you're getting power to the pump then the pump is bad or you have a bad ground. I'm sure it's just a bad pump.
You need to make sure you post some pics of that hinged door when you get it done.
Old Jul 13, 2012 | 12:31 AM
  #43
devic's Avatar
ok well i got the new racetronix pump in, new fuel filter, but im only getting 40 psi at the rail.
and the car will not bust over im only getting spark to certain plugs ?
when i first turn the key it trys to start then stops, i tried switching the coil packs but nothing
and i differently will but im prob not going to work on that till after i get everything working right
Old Jul 13, 2012 | 07:27 AM
  #44
USMC35thSS's Avatar
Around 40psi is what you should be getting until the car is running.
What do you mean by it tries to start then stops? Does the engine stop turning over? Has that battery been sitting for 3 years too?
You check spark at every plug while turning it over?
Old Jul 13, 2012 | 08:21 AM
  #45
devic's Avatar
i gets spark and gas for a moment, then it jus turns over
i started a more generalized threads to try and find the problem if its not dealing with fuel perhaps now, if you continue with ur greatly appreciated help on this page i would be great full good sir
full details on my car in this link
https://ls1tech.com/forums/generatio...oved-asap.html
